Aller au contenu principal
HP Pavilion 17-g119dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-g119dx RAM Replacement, Battery: étape 1, image 1 de 1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx RAM Replacement: étape 2, image 1 de 2 HP Pavilion 17-g119dx RAM Replacement: étape 2, image 2 de 2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx RAM Replacement: étape 3, image 1 de 2 HP Pavilion 17-g119dx RAM Replacement: étape 3, image 2 de 2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx RAM Replacement: étape 4, image 1 de 2 HP Pavilion 17-g119dx RAM Replacement: étape 4, image 2 de 2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx RAM Replacement, RAM: étape 5, image 1 de 3 HP Pavilion 17-g119dx RAM Replacement, RAM: étape 5, image 2 de 3 HP Pavilion 17-g119dx RAM Replacement, RAM: étape 5, image 3 de 3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx RAM Replacement: étape 6, image 1 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 6, image 2 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 6, image 3 de 3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx RAM Replacement: étape 7, image 1 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 7, image 2 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 7, image 3 de 3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx RAM Replacement: étape 8, image 1 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 8, image 2 de 3 HP Pavilion 17-g119dx RAM Replacement: étape 8, image 3 de 3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
    • After running the Plastic Opening Tool along the sides, you can gently lift the keyboard up and on top of the screen to access the RAM.
    • The RAM will be located above the Motherboard and next to the Processor.
  9. HP Pavilion 17-g119dx RAM Replacement: étape 11, image 1 de 2 HP Pavilion 17-g119dx RAM Replacement: étape 11, image 2 de 2
    • Release the RAM by pulling the two white levers away from the sides of the RAM.
  10. HP Pavilion 17-g119dx RAM Replacement: étape 12, image 1 de 1
    • Pull the RAM up and out of the laptop to remove it.
    • When reassembling, be sure to insert the RAM at the same angle it came out. Then push it down into place.
3 autres ont terminé cette réparation.
Morgan Best
Membre depuis le 10/30/17
403 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 15
Total : 2,401
