Aller au contenu principal
HP Pavilion 17-x047na Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-x047na Fan Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 17-x047na Fan Replacement, Battery: étape 1, image 2 de 2
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Fan Replacement: étape 2, image 1 de 1
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Fan Replacement, Back Panel: étape 3, image 1 de 2 HP Pavilion 17-x047na Fan Replacement, Back Panel: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Fan Replacement: étape 4, image 1 de 2 HP Pavilion 17-x047na Fan Replacement: étape 4, image 2 de 2
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Fan Replacement, Fan: étape 5, image 1 de 1
    • Remove the five screws attaching the fan to the motherboard using a Phillips #0.
    • Disconnect the wire connecting the fan to the motherboard.
  6. HP Pavilion 17-x047na Fan Replacement: étape 6, image 1 de 3 HP Pavilion 17-x047na Fan Replacement: étape 6, image 2 de 3 HP Pavilion 17-x047na Fan Replacement: étape 6, image 3 de 3
    • Using a Phillips # 0 screwdriver, remove the five 3.0 mm screws.
    • Disconnect the wire.
    • Then remove the fan.
Khaise Brice
Membre depuis le 10/30/19
459 Réputation
4 tutoriels rédigés
Équipe
University of Memphis, Team S4-G1, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S4-G1, Kim Fall 2019
UM-KIM-F19S4G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 15
Total : 203
