Aller au contenu principal
HP Pavilion 17-x047na Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-x047na Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 17-x047na Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: étape 3, image 1 de 2 HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion 17-x047na Hard Drive Replacement: étape 4, image 2 de 2
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Locate the hard drive.
  6. HP Pavilion 17-x047na Hard Drive Replacement: étape 6, image 1 de 3 HP Pavilion 17-x047na Hard Drive Replacement: étape 6, image 2 de 3 HP Pavilion 17-x047na Hard Drive Replacement: étape 6, image 3 de 3
    • To remove the hard drive, lift both latches to remove the ribbon cable.
    • Once ribbon cable is removed, use the rubber case surrounding the hard drive to lift upwards and pull the hard drive out.
Khaise Brice
Membre depuis le 10/30/19
459 Réputation
4 tutoriels rédigés
Équipe
University of Memphis, Team S4-G1, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S4-G1, Kim Fall 2019
UM-KIM-F19S4G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 9
Total : 415
