Aller au contenu principal
HP Pavilion DV2160BR DVD±RW Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: étape 1, image 1 de 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 2, image 1 de 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 2, image 2 de 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: étape 3, image 1 de 1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 4, image 1 de 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 4, image 2 de 2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 5, image 1 de 1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: étape 6, image 1 de 1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Brandon MacDonald
Membre depuis le 03/12/14
239 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 Membre de l'équipe UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 240
