Aller au contenu principal
HP Pavilion DV2160BR Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: étape 2, image 1 de 1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion DV2160BR Hard Drive Replacement: étape 3, image 2 de 2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: étape 4, image 1 de 1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: étape 5, image 1 de 3 HP Pavilion DV2160BR Hard Drive Replacement: étape 5, image 2 de 3 HP Pavilion DV2160BR Hard Drive Replacement: étape 5, image 3 de 3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Shannon
Membre depuis le 04/11/13
55 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 8
Total : 535
