Aller au contenu principal
HP Pavilion DV2160BR Inverter Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: étape 1, image 1 de 1
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: étape 2, image 1 de 3 HP Pavilion DV2160BR Inverter Replacement: étape 2, image 2 de 3 HP Pavilion DV2160BR Inverter Replacement: étape 2, image 3 de 3
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: étape 3, image 1 de 2 HP Pavilion DV2160BR Inverter Replacement: étape 3, image 2 de 2
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: étape 4, image 1 de 2 HP Pavilion DV2160BR Inverter Replacement: étape 4, image 2 de 2
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: étape 5, image 1 de 2 HP Pavilion DV2160BR Inverter Replacement: étape 5, image 2 de 2
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: étape 6, image 1 de 1
    • Remove the inverter from the device.
3 autres ont terminé cette réparation.
Shannon
Membre depuis le 04/11/13
55 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
Un commentaire
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 20
Total : 1,404
