Aller au contenu principal
HP Pavilion DV2160BR Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Keyboard Replacement: étape 2, image 1 de 2 HP Pavilion DV2160BR Keyboard Replacement: étape 2, image 2 de 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Keyboard Replacement, Keyboard: étape 3, image 1 de 3 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: étape 3, image 2 de 3 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Unscrew the 5 screws along the top edge of the laptop’s back panel and inside the battery compartment.
    • The two screws inside the battery compartment are 5mm Phillips #1.
    • The three screws outside the battery compartment are 9mm Phillips #1.
  4. HP Pavilion DV2160BR Keyboard Replacement: étape 4, image 1 de 3 HP Pavilion DV2160BR Keyboard Replacement: étape 4, image 2 de 3 HP Pavilion DV2160BR Keyboard Replacement: étape 4, image 3 de 3
    • Unscrew the three 6mm Phillips #1 screws that are marked by a keyboard symbol. These screws are holding in the keyboard itself.
  5. HP Pavilion DV2160BR Keyboard Replacement: étape 5, image 1 de 1
    • Flip the laptop over and open the lid.
  6. HP Pavilion DV2160BR Keyboard Replacement: étape 6, image 1 de 1
    • Using a blue plastic opening tool, remove the bezel by sliding the tool along the edges.
    • The bezel is held in place by plastic tabs, which you will hear snapping out of place as you slide the plastic opener tool.
    • You don't need to take the bezel all the way off the device, and shouldn't since it it connected to the laptop by two cables.
  7. HP Pavilion DV2160BR Keyboard Replacement: étape 7, image 1 de 1
    • Lift the keyboard from the device, starting from the top sides and pulling it away from the bottom end gently.
    • The keyboard is still connected by a cable, so don't pull too quickly.
  8. HP Pavilion DV2160BR Keyboard Replacement: étape 8, image 1 de 1
    • Disconnect the ribbon cable by gently pulling it out of the connector in the direction of the screen.
Shannon
Membre depuis le 04/11/13
55 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 19
Total : 823
