Aller au contenu principal
HP Pavilion DV2160BR RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR RAM Replacement, RAM: étape 1, image 1 de 2 HP Pavilion DV2160BR RAM Replacement, RAM: étape 1, image 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: étape 2, image 1 de 2 HP Pavilion DV2160BR RAM Replacement: étape 2, image 2 de 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: étape 3, image 1 de 3 HP Pavilion DV2160BR RAM Replacement: étape 3, image 2 de 3 HP Pavilion DV2160BR RAM Replacement: étape 3, image 3 de 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Shannon
Membre depuis le 04/11/13
55 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 380
