Aller au contenu principal
HP Pavilion DV2160BR Wifi Adapter Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: étape 1, image 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: étape 1, image 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: étape 2, image 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement: étape 2, image 2 de 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: étape 3, image 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement: étape 3, image 2 de 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Shannon
Membre depuis le 04/11/13
55 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-66, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 534
