Aller au contenu principal
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 2, image 1 de 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 2, image 2 de 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: étape 3, image 1 de 1
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 4, image 1 de 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 4, image 2 de 2
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 5, image 1 de 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 5, image 2 de 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 5, image 3 de 3
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 6, image 1 de 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 6, image 2 de 2
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 7, image 1 de 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: étape 7, image 2 de 2
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
Brandon Baldovin
Membre depuis le 09/30/13
548 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 1,649
