Aller au contenu principal
HP Pavilion DV3 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: étape 2, image 1 de 2 HP Pavilion DV3 Hard Drive Replacement: étape 2, image 2 de 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion DV3 Hard Drive Replacement: étape 4, image 2 de 2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: étape 5, image 1 de 3 HP Pavilion DV3 Hard Drive Replacement: étape 5, image 2 de 3 HP Pavilion DV3 Hard Drive Replacement: étape 5, image 3 de 3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
5 autres ont terminé cette réparation.
Luke Whitmarsh
Membre depuis le 09/30/13
649 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 4,985
