Aller au contenu principal
HP Pavilion DV5T-1000 Hard Drive Replacement
Ce dont vous avez besoin
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 2, image 1 de 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: étape 3, image 2 de 2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 4, image 1 de 1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 5, image 1 de 1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 6, image 1 de 1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 7, image 1 de 1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 8, image 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: étape 8, image 2 de 2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: étape 9, image 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
4 autres ont terminé cette réparation.
Josh Taimanglo
Membre depuis le 09/21/15
147 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 6-5, Mcmichael Fall 2015 Membre de l'équipe Colorado Springs, Team 6-5, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S6G5
4 membres
1 tutoriel rédigé
Un commentaire
Help after replacing hard drive installation of windows
Bettyjean Serrano - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 44
Total : 1,876
