Aller au contenu principal
HP Pavilion DV9700 Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: étape 1, image 1 de 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: étape 1, image 2 de 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: étape 1, image 3 de 3
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: étape 2, image 1 de 3 HP Pavilion DV9700 Optical Drive  Replacement: étape 2, image 2 de 3 HP Pavilion DV9700 Optical Drive  Replacement: étape 2, image 3 de 3
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Max Shangraw
Membre depuis le 03/19/18
507 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 17
Total : 358
