Aller au contenu principal
HP Pavilion DV9700 RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion DV9700 RAM Replacement, RAM: étape 1, image 1 de 2 HP Pavilion DV9700 RAM Replacement, RAM: étape 1, image 2 de 2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: étape 2, image 1 de 2 HP Pavilion DV9700 RAM Replacement: étape 2, image 2 de 2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: étape 3, image 1 de 3 HP Pavilion DV9700 RAM Replacement: étape 3, image 2 de 3 HP Pavilion DV9700 RAM Replacement: étape 3, image 3 de 3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: étape 4, image 1 de 3 HP Pavilion DV9700 RAM Replacement: étape 4, image 2 de 3 HP Pavilion DV9700 RAM Replacement: étape 4, image 3 de 3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Max Shangraw
Membre depuis le 03/19/18
507 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 17
Total : 771
