Aller au contenu principal
HP Pavilion G6-1d16dx Hard Drive Replacement
  1. HP Pavilion G6-1d16dx Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
    • Unscrew the two silver screws holding the protective cover in place.
    • The screws do not detach from the cover.
    • Remove Cover by lifting the edge along the battery compartment.
    • Slide the hard drive towards the empty gap, lift up on the hard drive, and remove it.
    • If the replacement hard drive lacks a rubber case- remove the rubber case that is around the old hard drive, and place it over the new hard drive.
    • Re-insert the hard drive, and slide it back into place.
Shyanne Bolton
Membre depuis le 04/05/18
468 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 99
