Introduction
Fans can attain a lot of dust and debris that will result in the fan becoming damaged. The fan is responsible for cooling the internal components of the computer. Replacing the fan will allow the HP Pavilion G60-120US to function normally again as well as run more efficiently.
Ce dont vous avez besoin
Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
Using the Phillips #0 screwdriver, remove the four 4mm screws from the midframe.
