Aller au contenu principal
HP Pavilion G60-235DX Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: étape 1, image 1 de 2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: étape 1, image 2 de 2
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: étape 2, image 1 de 3 HP Pavilion G60-235DX Keyboard  Replacement: étape 2, image 2 de 3 HP Pavilion G60-235DX Keyboard  Replacement: étape 2, image 3 de 3
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: étape 3, image 1 de 1
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
Gilbert Han
Membre depuis le 01/24/17
241 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-5, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 481
