Aller au contenu principal
HP Pavilion G60-247CL Speaker Replacement
Ce dont vous avez besoin
  1. HP Pavilion G60-247CL Speaker Replacement, Battery: étape 1, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement, Battery: étape 1, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement, Battery: étape 1, image 3 de 3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Speaker Replacement, Screen: étape 2, image 1 de 1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Speaker Replacement: étape 3, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 3, image 2 de 2
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Speaker Replacement: étape 4, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 4, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 4, image 3 de 3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  5. HP Pavilion G60-247CL Speaker Replacement: étape 5, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 5, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 5, image 3 de 3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Speaker Replacement: étape 6, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 6, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 6, image 3 de 3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Speaker Replacement: étape 7, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Speaker Replacement: étape 8, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 8, image 2 de 2
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Speaker Replacement: étape 9, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 9, image 2 de 2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Speaker Replacement: étape 10, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 10, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 10, image 3 de 3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Speaker Replacement: étape 11, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 11, image 2 de 2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Speaker Replacement: étape 12, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 12, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 12, image 3 de 3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Speaker Replacement: étape 13, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 13, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 13, image 3 de 3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Speaker Replacement: étape 14, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 14, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 14, image 3 de 3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Speaker Replacement: étape 15, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 15, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 15, image 3 de 3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Speaker Replacement: étape 16, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 16, image 2 de 2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Speaker Replacement: étape 17, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 17, image 2 de 2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Speaker Replacement: étape 18, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 18, image 2 de 2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Speaker Replacement: étape 19, image 1 de 1
    • Remove the screen from the outer casing carefully.
  20. HP Pavilion G60-247CL Speaker Replacement, RAM: étape 20, image 1 de 1
    • Locate RAM access door on the bottom side of the laptop.
  21. HP Pavilion G60-247CL Speaker Replacement: étape 21, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 21, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 21, image 3 de 3
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  22. HP Pavilion G60-247CL Speaker Replacement: étape 22, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 22, image 2 de 2
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  23. HP Pavilion G60-247CL Speaker Replacement: étape 23, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 23, image 2 de 2
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  24. HP Pavilion G60-247CL Speaker Replacement: étape 24, image 1 de 1
    • Gently lift the RAM stick up and out of its seat.
  25. HP Pavilion G60-247CL Speaker Replacement: étape 25, image 1 de 1
    • Repeat the previous two steps for the remaining stick of RAM.
  26. HP Pavilion G60-247CL Speaker Replacement, Speakers: étape 26, image 1 de 1
    • With the battery and RAM removed, locate the hard drive access panel.
  27. HP Pavilion G60-247CL Speaker Replacement: étape 27, image 1 de 1
    • Remove two 1.2 mm Philips#01 screws.
  28. HP Pavilion G60-247CL Speaker Replacement: étape 28, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 28, image 2 de 2
    • After the screws are removed, slide the hard drive panel to right to remove it.
  29. HP Pavilion G60-247CL Speaker Replacement: étape 29, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 29, image 2 de 2
    • Identify the three screws holding the hard drives cover in place.
    • Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  30. HP Pavilion G60-247CL Speaker Replacement: étape 30, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 30, image 2 de 2
    • Locate the storage battery, next to the hard drive.
    • Genlty pop out storage battery with fingers.
  31. HP Pavilion G60-247CL Speaker Replacement: étape 31, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 31, image 2 de 2
    • Locate the Wifi card cover panel, left of the RAM.
    • Using a Philips #1 screwdriver remove the screw holding the panel down.
  32. HP Pavilion G60-247CL Speaker Replacement: étape 32, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 32, image 2 de 2
    • Lift up on the screw side to remove the panel.
  33. HP Pavilion G60-247CL Speaker Replacement: étape 33, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 33, image 2 de 2
    • As the screws are removed the Wifi card will pop up.
  34. HP Pavilion G60-247CL Speaker Replacement: étape 34, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 34, image 2 de 2
    • Remove Wifi card by pulling to the left of the laptop.
  35. HP Pavilion G60-247CL Speaker Replacement: étape 35, image 1 de 1
    • Flip over to the top view
    • Remove five 1.2 mm Philips#00 swrews
  36. HP Pavilion G60-247CL Speaker Replacement: étape 36, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 36, image 2 de 2
    • Using a spudger unclip the casing around all corners and edges.
  37. HP Pavilion G60-247CL Speaker Replacement: étape 37, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 37, image 2 de 2
    • lift up the casing and remove to reveal the speakers.
  38. HP Pavilion G60-247CL Speaker Replacement: étape 38, image 1 de 1
    • Remove highlighted 1.2 mm Philips #00 screw from right speaker.
  39. HP Pavilion G60-247CL Speaker Replacement: étape 39, image 1 de 2 HP Pavilion G60-247CL Speaker Replacement: étape 39, image 2 de 2
    • Using a spudger, remove the highlighted white wire.
  40. HP Pavilion G60-247CL Speaker Replacement: étape 40, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 40, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 40, image 3 de 3
    • Using a spudger, remove both additional highlighted wires from the motherboad.
  41. HP Pavilion G60-247CL Speaker Replacement: étape 41, image 1 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 41, image 2 de 3 HP Pavilion G60-247CL Speaker Replacement: étape 41, image 3 de 3
    • Lift up and out each speaker from the base.
Zachary Herrera
Membre depuis le 03/20/18
485 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G5, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G5, Covino Spring 2018
UMASSD-COVINO-S18S4G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 302
