Aller au contenu principal
HP Pavilion G60-630US Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: étape 1, image 1 de 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: étape 1, image 2 de 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: étape 2, image 1 de 3 HP Pavilion G60-630US Hard Drive Replacement: étape 2, image 2 de 3 HP Pavilion G60-630US Hard Drive Replacement: étape 2, image 3 de 3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: étape 4, image 1 de 1
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: étape 5, image 1 de 1
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: étape 6, image 1 de 3 HP Pavilion G60-630US Hard Drive Replacement: étape 6, image 2 de 3 HP Pavilion G60-630US Hard Drive Replacement: étape 6, image 3 de 3
    • Lift up on black tap attached to the hard drive to remove the hard drive.
Nicole Welter
Membre depuis le 09/27/17
213 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 13
Total : 740
