Aller au contenu principal
HP Pavilion G7-2235DX RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion G7-2235DX RAM Replacement, Battery: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is properly shut down and charger is detached.
    • Slide the battery release switch to the center of the computer to release the battery.
  2. HP Pavilion G7-2235DX RAM Replacement: étape 2, image 1 de 1
    • Remove the battery.
  3. HP Pavilion G7-2235DX RAM Replacement, RAM: étape 3, image 1 de 2 HP Pavilion G7-2235DX RAM Replacement, RAM: étape 3, image 2 de 2
    • Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
  4. HP Pavilion G7-2235DX RAM Replacement: étape 4, image 1 de 2 HP Pavilion G7-2235DX RAM Replacement: étape 4, image 2 de 2
    • Slide the cover towards you, then pull up to remove it.
  5. HP Pavilion G7-2235DX RAM Replacement: étape 5, image 1 de 2 HP Pavilion G7-2235DX RAM Replacement: étape 5, image 2 de 2
    • Locate the RAM card and the two prongs holding it in place.
  6. HP Pavilion G7-2235DX RAM Replacement: étape 6, image 1 de 1
    • Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
  7. HP Pavilion G7-2235DX RAM Replacement: étape 7, image 1 de 1
    • The RAM card can now be pulled out at a slight angle.
Dante Mugnaini
Membre depuis le 10/13/16
219 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-7, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 448
