Aller au contenu principal
HP Pavilion G7-2235DX Screen Replacement
Ce dont vous avez besoin
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: étape 1, image 1 de 1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: étape 2, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: étape 3, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 3, image 2 de 2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: étape 4, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 4, image 2 de 2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: étape 5, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 5, image 2 de 2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: étape 6, image 1 de 1
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: étape 7, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 7, image 2 de 2
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: étape 8, image 1 de 2 HP Pavilion G7-2235DX Screen Replacement: étape 8, image 2 de 2
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
2 autres ont terminé cette réparation.
Bre'Anna Sanders
Membre depuis le 10/11/16
113 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-7, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 480
