Aller au contenu principal
HP Pavilion N3350 Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: étape 1, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement, Keyboard: étape 1, image 2 de 2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 2, image 2 de 2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: étape 3, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 3, image 2 de 2
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: étape 4, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: étape 4, image 2 de 2
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: étape 5, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: étape 6, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 6, image 2 de 2
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: étape 7, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 7, image 2 de 2
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: étape 8, image 1 de 2 HP Pavilion N3350 Optical Drive Replacement: étape 8, image 2 de 2
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
Lyndon Davis
Membre depuis le 03/19/18
124 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 248
