Introduction
If you are using a sound card, video card, or network card in your laptop, they are inserted into the PCI slot. If they are malfunctioning, they need to be replaced or cleaned. Once the respective replacement is purchased, follow the guide to replace.
Pièces
Aucune pièce nécessaire.
Locate the PCI port, it is next to the CD drive on the right side of the laptop.
  • Locate the PCI port, it is next to the CD drive on the right side of the laptop.
Ajouter un commentaire
Use a spudger to open the button that disengages the card from the slot.
  • Use a spudger to open the button that disengages the card from the slot.
  • Once popped out, press the button and the inserted PCI should eject and be removed easily.
  • Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot.
Emily Hatstat
Membre depuis le 19/03/2018
481 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 17
