Introduction
If the screen of your laptop is black when powered on, or cracked, it should be replaced. With the purchase of a new screen, follow these steps to replace it completely.
Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
  • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
  • To remove this, pry it open with a spudger tool gently. It should pop out of place.
Ajouter un commentaire
Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
  • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
  • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
  • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
  • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
  • Remove the 6 rubber screw caps with a metal spudger.
  • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
  • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
  • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
  • Remove the top plastic cover once all connections have been released.
  • Disconnect the connectors using a plastic opening tool.
  • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
  • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
  • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
  • Remove the screen from the device.
Emily Hatstat
Membre depuis le 19/03/2018
481 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 24
