Aller au contenu principal
HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 2, image 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 2, image 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 2, image 3 de 3
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 3, image 2 de 2
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 4, image 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 4, image 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 4, image 3 de 3
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 5, image 1 de 1
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 6, image 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 6, image 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 6, image 3 de 3
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 7, image 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 7, image 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 7, image 3 de 3
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 8, image 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: étape 8, image 2 de 2
    • Once you release the white tab from the green board, remove the hard drive.
Efren Solis
Membre depuis le 09/10/18
228 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G2, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 66
Total : 2,842
