Aller au contenu principal
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: étape 1, image 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: étape 1, image 2 de 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 2, image 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 2, image 2 de 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 3, image 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 3, image 2 de 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 5, image 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 5, image 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 5, image 3 de 3
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 6, image 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 6, image 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 6, image 3 de 3
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 7, image 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 7, image 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 7, image 3 de 3
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 8, image 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 8, image 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 8, image 3 de 3
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 9, image 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 9, image 2 de 2
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 10, image 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 10, image 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 10, image 3 de 3
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 11, image 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: étape 11, image 2 de 2
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
Josh Svik
Membre depuis le 04/10/18
281 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 372
