Introduction
This guide will walk you through the step by step process to remove the mother board from your laptop. You will need to do this if you are having issues with the laptop booting or to remove the WiFi card or RAM.
Pièces
Aucune pièce nécessaire.
  1. Unplug laptop  from adapter and all other devices.
    • Unplug laptop from adapter and all other devices.
  2. Flip the laptop over with battery facing you.
    • Flip the laptop over with battery facing you.
  3. Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Pull battery out.
    • Pull battery out.
  5. Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Push screwdriver through screw hole top  pop the keyboard.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  8. Pry up the keyboard.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  9. Remove keyboard  wire  by popping latch under blue  plastic
    • Remove keyboard wire by popping latch under blue plastic
  10. Using the spudger to lift up on the white  tabs
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  11. Remove the five 5.5mm Phillips #1 screws from the case
    • Remove the five 5.5mm Phillips #1 screws from the case
  12. Remove eight 6.5mm Phillips #1 screws from the back cover
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  13. Starting at a top corner, use the pry tool to split the case. Slowly work around the case, pulling up gently to release the clips. Slowly work around the case, pulling up gently to release the clips.
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  14. Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
    • Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
  15. Remove hard drive from bracket being careful of it's cable.
    • Remove hard drive from bracket being careful of it's cable.
  16. Disconnect cable from hard drive.
    • Disconnect cable from hard drive.
  17. Disconnect motherboard cable from left side USB and jacks Disconnect motherboard cable from left side USB and jacks
    • Disconnect motherboard cable from left side USB and jacks
  18. Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  19. Remove motherboard.
    • Remove motherboard.
Sam Barkley
Membre depuis le 13/02/2018
959 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 76
