Aller au contenu principal
HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: étape 1, image 1 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: étape 1, image 2 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: étape 1, image 3 de 3
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Replacing Keyboard: étape 2, image 1 de 1
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: étape 3, image 1 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: étape 3, image 2 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: étape 3, image 3 de 3
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  4. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: étape 4, image 1 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: étape 4, image 2 de 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: étape 4, image 3 de 3
    • Locate and remove the silver hard drive cover in the bottom right corner.
  5. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: étape 5, image 1 de 1
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
12 autres ont terminé cette réparation.
Rashed
Membre depuis le 01/13/15
670 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 3-3, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 membres
5 tutoriels rédigés
6 commentaires
Fatto per il modello 15-b131el!!
Simone Milesi - Réponse
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - Réponse
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - Réponse
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - Réponse
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 17,358
