Aller au contenu principal
HP Pavilion TPN-C125 RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion TPN-C125 RAM Replacement, RAM: étape 1, image 1 de 2 HP Pavilion TPN-C125 RAM Replacement, RAM: étape 1, image 2 de 2
    • Flip the laptop over so the bottom is facing up and the external battery is at the top.
  2. HP Pavilion TPN-C125 RAM Replacement: étape 2, image 1 de 2 HP Pavilion TPN-C125 RAM Replacement: étape 2, image 2 de 2
    • Use your thumbs to slide the battery locks towards the center and pop the battery out.
  3. HP Pavilion TPN-C125 RAM Replacement: étape 3, image 1 de 2 HP Pavilion TPN-C125 RAM Replacement: étape 3, image 2 de 2
    • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
    • This will expose two Philips #00 10 mm screws required to remove the back plate.
    • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
  4. HP Pavilion TPN-C125 RAM Replacement: étape 4, image 1 de 2 HP Pavilion TPN-C125 RAM Replacement: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
    • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
    • You will hear a "click" as you release the clips and remove it.
  5. HP Pavilion TPN-C125 RAM Replacement: étape 5, image 1 de 3 HP Pavilion TPN-C125 RAM Replacement: étape 5, image 2 de 3 HP Pavilion TPN-C125 RAM Replacement: étape 5, image 3 de 3
    • The RAM sticks can be found in the bottom right section of the laptop.
    • Push both side arms holding the RAM stick in place outwards.
    • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
    • Slide the RAM sticks out of the socket gently.
  6. HP Pavilion TPN-C125 RAM Replacement: étape 6, image 1 de 3 HP Pavilion TPN-C125 RAM Replacement: étape 6, image 2 de 3 HP Pavilion TPN-C125 RAM Replacement: étape 6, image 3 de 3
    • Carefully slide the new replacement RAM sticks into their slots.
    • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
    • Gently push the RAM sticks downward until the latches click into place to secure them.
Cesar Gomez
Membre depuis le 03/05/24
183 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 7-10, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 7-10, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G10
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 70
Total : 169
