Aller au contenu principal
HP Pavilion Touchsmart 11z-e000 Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: étape 1, image 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: étape 2, image 1 de 1
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: étape 3, image 1 de 1
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: étape 4, image 1 de 1
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: étape 5, image 1 de 1
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: étape 6, image 1 de 1
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
Nguyen
Membre depuis le 01/22/15
301 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-22, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 1,125
