Introduction
This guide will help give direction to properly remove the RAM and access the motherboard of your HP Pavilion Wave Desktop PC. Tools required for this removal include Phillips and Torx head screwdrivers, metal and plastic prying tools, and a magnetic arrangement pad.
Ce dont vous avez besoin
Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
Remove the three 24 mm screws that connect the top cover to the chasis inside the HDD compartment using theTorx #15 screwdriver (an extension and torque lever might be useful).
Remove the top chassis cover from the main chassis using the Torx Head #15 screwdriver to remove the nine 24 mm screws and then use the metal prying tool to pry the top chassis cover from the clips holding it to the main chassis and lift carefully away from internal components.
Remove the memory cover by removing the single 24 mm screw holding it to the main chassis using the Torx Head #15 screwdriver and sliding it up and out of its locking clips.
Remove the heatsink from the chassis by using the Philips Head #2 screwdriver to remove two 24 mm screws.
2 autres ont terminé cette réparation.
2 commentaires
Perfect unmount description, exept one point no. Sep 9 .. two screws are below the dard drive cover, one need a longer screwdriver shaft to open.
Where can I buye a mainboard replacement, I assume the exiting display controller is defect.
Thanks for your support.
Martin
Pauli.At.Mb@gmail.com
Step 6 what is the wire on top for
