Aller au contenu principal
HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: étape 1, image 1 de 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: étape 1, image 2 de 2
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 2, image 1 de 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 2, image 2 de 2
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 3, image 1 de 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 3, image 2 de 2
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: étape 4, image 1 de 1
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: étape 5, image 2 de 2
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
4 autres ont terminé cette réparation.
Kyaw Soe
Membre depuis le 09/27/17
321 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S8-G4, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 membres
5 tutoriels rédigés
3 commentaires
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - Réponse
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - Réponse
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 21
Total : 2,313
