Aller au contenu principal
HP Pavilion ZD7000 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 1 de 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 2 de 2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: étape 4, image 1 de 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
3 autres ont terminé cette réparation.
Shantel
Membre depuis le 04/20/10
545 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 30-37, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 membres
6 tutoriels rédigés
2 commentaires
Can you upgrade the wifi card?
danoco - Réponse
is there a replacement I can buy
Braeden Culp - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 19
Total : 5,451
