Aller au contenu principal
HP Pavilion dv2000 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Phillips #00 Screwdriver
    $5.49
    J'achète
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: étape 2, image 1 de 3 HP Pavilion dv2000 Hard Drive Replacement: étape 2, image 2 de 3 HP Pavilion dv2000 Hard Drive Replacement: étape 2, image 3 de 3
    Phillips #000 Screwdriver
    $5.49
    J'achète
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
7 autres ont terminé cette réparation.
Erik Muniz
Membre depuis le 09/09/14
820 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 membres
3 tutoriels rédigés
Un commentaire
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 4,216
