Aller au contenu principal
HP Pavilion dv2000 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: étape 1, image 1 de 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: étape 1, image 2 de 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: étape 2, image 1 de 2 HP Pavilion dv2000 Wireless Card Replacement: étape 2, image 2 de 2
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: étape 3, image 1 de 3 HP Pavilion dv2000 Wireless Card Replacement: étape 3, image 2 de 3 HP Pavilion dv2000 Wireless Card Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Phillips #00 Screwdriver
    $5.49
    J'achète
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
3 autres ont terminé cette réparation.
Erik Muniz
Membre depuis le 09/09/14
820 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 22
Total : 2,200
