Aller au contenu principal
HP Pavilion dv2700 Camera Module Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: étape 1, image 1 de 1
    • Disconnect device from power source and power down.
    • Disconnect any other external devices.
  2. HP Pavilion dv2700 Camera Module Replacement: étape 2, image 1 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 2, image 2 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 2, image 3 de 3
    • Flip the laptop over so that the bottom is facing upwards.
    • Use your index finger to push the battery latch.
    • Pivot the battery upward and lift it out of the socket to remove it.
  3. HP Pavilion dv2700 Camera Module Replacement: étape 3, image 1 de 1
    • Flip the laptop right side up.
    • Open it as wide as the hinge allows it to.
  4. HP Pavilion dv2700 Camera Module Replacement: étape 4, image 1 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 4, image 2 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 4, image 3 de 3
    • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
    • Remove the Phillips PM2.5×5.0 screws.
    • Remove the two rubber screw covers located at the bottom left and right of the bezel.
  5. HP Pavilion dv2700 Camera Module Replacement: étape 5, image 1 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 5, image 2 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 5, image 3 de 3
    • Flex the inside edges of the left and right sides and the top edge of the display bezel.
    • Lift the bezel with your finger until it disengages from the display enclosure.
  6. HP Pavilion dv2700 Camera Module Replacement: étape 6, image 1 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 6, image 2 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 6, image 3 de 3
    • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
    • Release the camera module assembly unit by simply pulling it out of the laptop.
  7. HP Pavilion dv2700 Camera Module Replacement: étape 7, image 1 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 7, image 2 de 3 HP Pavilion dv2700 Camera Module Replacement: étape 7, image 3 de 3
    • Disconnect the camera module cable from the camera module itself by pulling it out.
    • Be careful not to break the camera module cable.
    • Turn the module upside down and remove the screws for the camera bracket.
    • Remove the camera module from the bracket.
Kayaen Jardine
Membre depuis le 07/05/20
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G35, Allen Summer 2020 Membre de l'équipe York University, Team S1-G35, Allen Summer 2020
YORK-ALLEN-SU20S1G35
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 14
Total : 457
