Aller au contenu principal
HP Pavilion dv2700 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: étape 2, image 1 de 1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: étape 3, image 1 de 1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion dv2700 Hard Drive Replacement: étape 4, image 2 de 2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
2 autres ont terminé cette réparation.
Jared Opperman
Membre depuis le 09/24/15
161 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 22-6, Rauch Fall 2015 Membre de l'équipe Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
3 membres
2 tutoriels rédigés
Un commentaire
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 2,977
