Aller au contenu principal
HP Pavilion dv2913cl Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: étape 2, image 1 de 1
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: étape 3, image 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: étape 3, image 2 de 2
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: étape 4, image 1 de 1
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: étape 6, image 2 de 2
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
Adam Braga
Membre depuis le 10/24/16
230 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 152
