Aller au contenu principal
HP Pavilion dv4000 CD/DVD drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: étape 2, image 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: étape 3, image 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: étape 5, image 1 de 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: étape 6, image 1 de 2 HP Pavilion dv4000 CD/DVD drive Replacement: étape 6, image 2 de 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: étape 7, image 1 de 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: étape 8, image 1 de 2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: étape 8, image 2 de 2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: étape 9, image 1 de 3 HP Pavilion dv4000 CD/DVD drive Replacement: étape 9, image 2 de 3 HP Pavilion dv4000 CD/DVD drive Replacement: étape 9, image 3 de 3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: étape 10, image 1 de 2 HP Pavilion dv4000 CD/DVD drive Replacement: étape 10, image 2 de 2
    • Carefully grasp the DVD drive and slide it out.
4 autres ont terminé cette réparation.
Nick LaMarche
Membre depuis le 10/18/16
373 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 1,128
