Aller au contenu principal
HP Pavilion dv4000 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: étape 3, image 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: étape 5, image 1 de 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: étape 6, image 1 de 2 HP Pavilion dv4000 Hard Drive Replacement: étape 6, image 2 de 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: étape 7, image 1 de 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
To replace the hard drive, follow these instructions in reverse.
Chris Marshall
Membre depuis le 10/18/16
454 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 1,829
