Aller au contenu principal
HP Pavilion dv4000 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Keyboard Replacement: étape 3, image 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Have your device open in front of you for easy access to the keyboard.
  5. HP Pavilion dv4000 Keyboard Replacement: étape 5, image 1 de 1
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
  6. HP Pavilion dv4000 Keyboard Replacement: étape 6, image 1 de 1
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
  7. HP Pavilion dv4000 Keyboard Replacement: étape 7, image 1 de 3 HP Pavilion dv4000 Keyboard Replacement: étape 7, image 2 de 3 HP Pavilion dv4000 Keyboard Replacement: étape 7, image 3 de 3
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
  8. HP Pavilion dv4000 Keyboard Replacement: étape 8, image 1 de 1
    • Locate the four 2x2 mm screws that hold the keyboard in place.
  9. HP Pavilion dv4000 Keyboard Replacement: étape 9, image 1 de 1
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
  10. HP Pavilion dv4000 Keyboard Replacement: étape 10, image 1 de 2 HP Pavilion dv4000 Keyboard Replacement: étape 10, image 2 de 2
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
  11. HP Pavilion dv4000 Keyboard Replacement: étape 11, image 1 de 1
    • Locate where the ribbon strip is connected to the motherboard.
  12. HP Pavilion dv4000 Keyboard Replacement: étape 12, image 1 de 2 HP Pavilion dv4000 Keyboard Replacement: étape 12, image 2 de 2
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
  13. HP Pavilion dv4000 Keyboard Replacement: étape 13, image 1 de 3 HP Pavilion dv4000 Keyboard Replacement: étape 13, image 2 de 3 HP Pavilion dv4000 Keyboard Replacement: étape 13, image 3 de 3
    • Remove the keyboard.
Nick LaMarche
Membre depuis le 10/18/16
373 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 23
Total : 936
