Introduction
The motherboard is the main part of the computer and houses the CPU and GPU. Although it is rare to encounter problems with the motherboard, it needs to be removed to access the fan and heat sink underneath.
Ce dont vous avez besoin
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
The white wire connects to the AUX terminal.
The black wire connects to the MAIN terminal.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Use the plastic prying tool to disconnect the screen cable from the system board.
Flip the computer over to access the screws on the underside of the frame.
Remove the two 3.0mm screws.
Remove the 5.0mm screw.
8 autres ont terminé cette réparation.
