Introduction
This guide will tell you how to remove the optical drive, or CD/DVD drive.
Outils
Pièces
Aucune pièce spécifiée.
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
