Aller au contenu principal
HP Pavilion dv6-1245dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: étape 1, image 1 de 1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: étape 2, image 1 de 1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: étape 3, image 1 de 1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: étape 4, image 1 de 1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: étape 5, image 1 de 3 HP Pavilion dv6-1245dx RAM Replacement: étape 5, image 2 de 3 HP Pavilion dv6-1245dx RAM Replacement: étape 5, image 3 de 3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: étape 6, image 1 de 1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
4 autres ont terminé cette réparation.
Jaime
Membre depuis le 01/23/14
562 Réputation
1 tutoriel rédigé
Équipe
New Mexico State, Team 1-3, Sheppard Spring 2014 Membre de l'équipe New Mexico State, Team 1-3, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 19
Total : 2,389
