Aller au contenu principal
HP Pavilion dv6-2158nr RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-2158nr RAM Replacement, Battery: étape 1, image 1 de 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: étape 1, image 2 de 3 HP Pavilion dv6-2158nr RAM Replacement, Battery: étape 1, image 3 de 3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr RAM Replacement, RAM: étape 2, image 1 de 1
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. HP Pavilion dv6-2158nr RAM Replacement: étape 3, image 1 de 3 HP Pavilion dv6-2158nr RAM Replacement: étape 3, image 2 de 3 HP Pavilion dv6-2158nr RAM Replacement: étape 3, image 3 de 3
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  4. HP Pavilion dv6-2158nr RAM Replacement: étape 4, image 1 de 3 HP Pavilion dv6-2158nr RAM Replacement: étape 4, image 2 de 3 HP Pavilion dv6-2158nr RAM Replacement: étape 4, image 3 de 3
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Chad
Membre depuis le 01/13/14
1 123 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 10-34, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 1,538
