Aller au contenu principal
HP Pavilion dv6-6117dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 2, image 1 de 2 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 2, image 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 3, image 1 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 3, image 2 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 3, image 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 4, image 1 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 4, image 2 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 4, image 3 de 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 5, image 1 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 5, image 2 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 5, image 3 de 3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 6, image 1 de 2 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 6, image 2 de 2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 7, image 1 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 7, image 2 de 3 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 7, image 3 de 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 8, image 1 de 2 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 8, image 2 de 2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: étape 9, image 1 de 2 HP Pavilion dv6-6117dx Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the SATA cable from the hard drive.
4 autres ont terminé cette réparation.
Joshua Holme
Membre depuis le 03/19/18
765 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 43
Total : 2,535
