Aller au contenu principal
HP Pavilion dv6-6117dx Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: étape 1, image 1 de 2 HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: étape 1, image 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 2, image 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Optical Drive Replacement: étape 3, image 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 3, image 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 3, image 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Optical Drive Replacement: étape 4, image 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 4, image 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 4, image 3 de 3
    • Using a Phillips #0 screw driver, remove the single 4mm screw holding the optical drive in place
  5. HP Pavilion dv6-6117dx Optical Drive Replacement: étape 5, image 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 5, image 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: étape 5, image 3 de 3
    • Using a plastic spudger, push the optical drive out toward the left of the device
Joshua Holme
Membre depuis le 03/19/18
765 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 306
