Aller au contenu principal
HP Pavilion dv6-6117dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: étape 1, image 1 de 2 HP Pavilion dv6-6117dx RAM Replacement, RAM: étape 1, image 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: étape 2, image 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: étape 2, image 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: étape 3, image 1 de 3 HP Pavilion dv6-6117dx RAM Replacement: étape 3, image 2 de 3 HP Pavilion dv6-6117dx RAM Replacement: étape 3, image 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: étape 4, image 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: étape 4, image 2 de 2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: étape 5, image 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: étape 5, image 2 de 2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Joshua Holme
Membre depuis le 03/19/18
765 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 22
Total : 737
