Aller au contenu principal
HP Pavilion dv6-6117dx WiFi Adapter Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: étape 1, image 1 de 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: étape 1, image 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 2, image 1 de 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 2, image 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 3, image 1 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 3, image 2 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 3, image 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 4, image 1 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 4, image 2 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 4, image 3 de 3
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 5, image 1 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 5, image 2 de 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 5, image 3 de 3
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 6, image 1 de 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: étape 6, image 2 de 2
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
2 autres ont terminé cette réparation.
Joshua Holme
Membre depuis le 03/19/18
765 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 membres
4 tutoriels rédigés
Un commentaire
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 41
Total : 2,351
