Aller au contenu principal
HP Pavilion dv6500 Screen Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6500 Screen Replacement, Battery: étape 1, image 1 de 1
    • Flip computer face down.
  2. HP Pavilion dv6500 Screen Replacement: étape 2, image 1 de 1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Screen Replacement, Back Panel: étape 3, image 1 de 1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Screen Replacement, Keyboard: étape 4, image 1 de 2 HP Pavilion dv6500 Screen Replacement, Keyboard: étape 4, image 2 de 2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  5. HP Pavilion dv6500 Screen Replacement: étape 5, image 1 de 1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Screen Replacement: étape 6, image 1 de 1
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Screen Replacement: étape 7, image 1 de 1
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
  8. HP Pavilion dv6500 Screen Replacement, Screen: étape 8, image 1 de 3 HP Pavilion dv6500 Screen Replacement, Screen: étape 8, image 2 de 3 HP Pavilion dv6500 Screen Replacement, Screen: étape 8, image 3 de 3
    • Remove the four 7mm screws holding screen to keyboard, there are 2 on each side.
  9. HP Pavilion dv6500 Screen Replacement: étape 9, image 1 de 3 HP Pavilion dv6500 Screen Replacement: étape 9, image 2 de 3 HP Pavilion dv6500 Screen Replacement: étape 9, image 3 de 3
    • Unplug all cables connected to the monitor on the left side. The thick black cable should come out with a simple tug.
    • Turn over laptop and unscrew 7mm fastener holding wires in place and pull the wires through the laptop to the other side.
  10. HP Pavilion dv6500 Screen Replacement: étape 10, image 1 de 1
    • Feed the cables through the laptop and lift the monitor from the rest of the computer.
3 autres ont terminé cette réparation.
ollie
Membre depuis le 10/20/16
575 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 1,994
